13-02-2006, 07:18 AM #1
heating coil in front of duct unit
i was wondering if someone can point me maybe to another thread about this issue, or maybe used this method for heating...and if this coil can be controled through the wired remote control and the duct unit to work only on ventilation in the winter. and maybe some data about how much the air flow is reduced ?!?!
Thanks.
"do not follow where the path may lead. go instead where there is no path and leave a trail" R.W.Emerson
13-02-2006, 08:33 AM #2
Re: heating coil in front of duct unit
what type of coil? It's general to use heat coil in duct ventilation. How the air flow is influenced depends on the fan pressure head and the duct resistance.
rgds
LCI hear...I forget;I see...I remember;I do...I understand
13-02-2006, 11:04 AM #3
thanks LC,
i didn't say anything about the unit or the coil because it doesn't matter (it's my problem to solve)...just looking for an example about air flow. and i say again : (on no matter what brand name) can i use the remote control to do this..?
P.S. maybe i didn't make my self very clear...i'm not sure even now it's better..
Rgds,
cruz"do not follow where the path may lead. go instead where there is no path and leave a trail" R.W.Emerson
13-02-2006, 11:32 PM #4
Cruz, if I understand you correctly you are trying to use a ducted a/c unit, cooling only, as a cooler in the summer; when winter comes you want to use a heater battery as the heat source.
The heater battery to be placed in the ducted airflow of the unit.
The a/c control to switch some form of valve in the heating coil when heat is required.
If this is correct then i'm sure that it can be done. It is difficult to give facts and figures about the effect on air flow as we do not know the size/model or airflow of the ducted unit. We also do not know the size/type of the heater battery so it is impossible for us to give you figures on the expected pressure drops across the coil and how much the air flow will be affected.
More information is required, sorry... BrianBrian - Newton Abbot, Devon, UK
Problem with ducted Daikin
By jutty in forum Trouble ShootingReplies: 8Last Post: 23-07-2007, 05:34 AM -
air cooling and heating coil test
By Lc_shi in forum Technical SpeculationsReplies: 8Last Post: 23-02-2006, 01:15 AM -
Lennox fan coil unit question
By THERMOACC in forum FundamentalsReplies: 2Last Post: 17-02-2006, 10:31 PM -
dry fan coil unit
By Lc_shi in forum New TechnologiesReplies: 6Last Post: 18-05-2005, 02:29 AM -
Selecting Evaporator coil and condensing unit
By Abe in forum Tools and CalculatorsReplies: 7Last Post: 04-04-2003, 03:20 PM
