03-07-2013, 08:11 PM #1
help-Working Principle of Electronic Expansion Valve
Hi every body ,hope you all will be in sound health and enjoying all in your own way.
I want to know one point regarding working of electronic expansion valve .
A thermistor conveys superheat condition through a circuit to heater with negative temperature resistance coefficient. My question is that how does heater operate needle valve to allow more or less refrigerant to evaporator?
Thanks in advance
03-07-2013, 08:35 PM #2
Re: help-Working Principle of Electronic Expansion Valve
03-07-2013, 09:35 PM #3
Thank you sir for your kind reply but my point is still not clear.
The type of expansion valve in link you posted above is different to which I asked.
Please see the following link and read the electronic expansion valve section from where my question originated.
http://www.google.com.pk/url?sa=t&rc...,d.bGE&cad=rjaLast edited by pakblogger2012; 03-07-2013 at 09:37 PM.
03-07-2013, 10:26 PM #4
The heater probably heats a fluid which will then expand and move the valve needle.
Never seen one myself as now-a-days we tends to use electric stepper motors to drive the valve up and down.Brian - Newton Abbot, Devon, UK
03-07-2013, 10:26 PM #5
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
This is done by electrochemical actuator. It is consisted of heater around thermal actuator. Current of heater is regulated through thermistor which senses evaporator exit temperature.
Thermal actuator:
04-07-2013, 05:01 AM #6
Thank you nike123,but one thing is still not clear .
In figure you posted above ,it seems that at higher current actuator will give narrow path for refrigerant flow but actually opposite happens ,above figure does not match actual working of electonic valve.
your guidance please
04-07-2013, 06:33 AM #7
04-07-2013, 06:23 AM #8
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
This is principle of function of piston in valve. Opposite action can be done by spring in assembly. Momentary, I don't have any picture of actual valve.
