12-02-2006, 09:34 AM #1
Cu/Ni condenser,32 bar,9 kW for R410A/salted water
Hello,
for our new generation of swimming pool heat pumps, we need to switch over to the new refrigerant R410A, which means we need a pressure rating on the refrigerant side at least 32 bar (450 psig?).
At the same moment we need to use salted pool water on the secondary side.
Can anybody deliver any condenser 32 bar, 9 kW capable of handling salted water? (Cu/Ni, titanium coaxial possibly)
I am ready to send the calculation of a (plate) condenser that we need to replace.
Awaiting any suggestion.
with advance thanks
Martin Pekarek
info@vymeniky.cz
Re: Cu/Ni condenser,32 bar,9 kW for R410A/salted water
www.alfalaval.com
very satisfied with their plate exchangers, we use them as seawater cooled condensers on RSW plants with ammonia.
12-02-2006, 11:27 PM #3
Why are you using R-410a on a heat pump? I would almost certainly recommend a lower pressure refrigerant for heat pumps.
02-03-2006, 04:38 PM #4
Originally Posted by US Iceman
Pretty much all the heat pumps in the Uk are now 410a
cheers
richard
02-03-2006, 07:49 PM #5
What's the company's website?
Fact or Fiction
By david.findlay in forum FundamentalsReplies: 40Last Post: 09-03-2009, 06:19 PM -
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
By Vymeniky in forum Technical SpeculationsReplies: 1Last Post: 18-02-2006, 09:43 PM -
Comments on this please
By Robearbam in forum FundamentalsReplies: 8Last Post: 18-04-2005, 05:20 PM -
Building a wine cabinet
