    Mar 2010
    Vietnam
    Volume of Chilled Water in the System
    Greetings to all,
    Kindly advise how to calculate the volume of chilled water to fill inside the closed circuit. Is it the same as internal volume of the pipe?
    Feb 2007
    2,473
    Re: Volume of Chilled Water in the System
    Well, yes...
    + The internal volume of all the equipment attached to it, like chillers/fan coils/expansion vessels and so on.
    Apr 2011
    India
    94
    13
    If you have an expansion/ make-up tank, make sure that it is also full with water.Keep an eye on the tank while charging the whole circuit with water.Air locking is a critical issue occurs when we charge the empty lines.Hence make sure you have air purging valves on the CHW lines or provide the appropriate points to remove the air from the system.If we charge the system with proper care, we can prevent the problems related to air locking.
    Dec 2008
    Portugal
    48
    1,020
    Quote Originally Posted by Sumit View Post
    Yes, that's right.
    Lh.ahn84, you can apply automatic air purgers on the critical points.
    There is a variety of prices of types. You can buy it in Portugal from 50...120 Euros. However the range of prices can be larger.
    Sarco it's one of the brands.
