Results 1 to 10 of 10
Thread: Daikin Euwa
    Feb 2006
    Poland
    5
    Exclamation Daikin Euwa
    Dear all
    I`m looking for service documentation for Daikin chiller Daikin EUWA100HASDY1 1998 380047. ( two compressors) One of compressor is starting operation and stops after 0.5 seconds. Unit was switched off for 3 months. Range of outside temperature during iddle state -25 : - 10 deg C. I checked amount of refrigerant -OK. The controller after shutting off the compressor indicate alarm led without any description also compressor motor protection is off. . No idea if oil can migrate from compressor ( heater was on during mentioned 3 months). Is it possible that having documentation i can check in the control panel what is the reason of failure. ???
    Thanks for help
    Best regards.
    Oct 2001
    Nottingham UK
    5,668
    Re: Daikin Euwa
    I've got the info at the office. I'll post the error codes tomorrow
    Feb 2006
    Poland
    5
    Re: Daikin Euwa
    It will be great if you can send me any information. I cant find anything in my country because the unit wasnt bought by factory from Daikin in Poland but was imported as second hand from abroad. That is the reason nobody hear about this model before in our regional offices.
    I chcecked the controller but it needs a password. The company which installed the unit,does not exist. Nobody knows password. I ve read manual from similar model EUWA MZSDY The standar password is 1234 but in my controller there are not buttons with digit, only arrows + and - enter key etc.
    If you can sent me any information it will be fine. If it impossible because of the size in MB you can send me this via post office ang charge me.
    Best regards
    Sep 2005
    Granard, Ireland
    55
    43
    Re: Daikin Euwa
    Rysiozklanu
    Will the second compressor start and run?
    Check voltage.
    I will have a look for a pdf manual i have some place.
    regards
    Feb 2006
    Poland
    5
    Re: Daikin Euwa
    The first compressor runs without any problem. The second runs 2 - 3 seconds. I have not enough time to diagnose it.
    Oct 2001
    Nottingham UK
    5,668
    Re: Daikin Euwa
    Fault Codes
    A1 Anti-freeze alarm
    E1 Evap Inlet water temp NTC Probe defective
    E2 Evap Outlet water temp NTC Probe defective
    E3 Evap heater tape fuse blown or reverse phase error or PCB error
    EE, EP EEprom defective
    EU, EO Supply voltage low (EU) or exceedingly high (EO)
    EL Power supply is excessively noisey
    FL Low water flow or pump overload activated
    H1 High Pressure switch activated
    L1 Low pressure switch activated
    if FL and H1 flash alternately then you have a reverse phase problem
    n1 Indicates that compressor 1 requires routine maintenance
    n2 Indicates that compressor 2 requires routine maintenance
    Press the SEL key for 5 seconds to adjust the parameters
    r1 cooling temp setpoint
    r2 colling temp differential
    r6 check evap water outlet temp
    c9 check total running hours of comp 1
    cA check total running hours of comp 2
    cC check total running hours of pump
    The password is 22 - Factory default
    Press PRG key for 5 seconds
    number 00 starts flashing
    Enter 22 using the up/down arrows
    Press SEL key to confirm
    the controller then displays rd which is the first parameter.
    Let me know if you need the parameter list (it's rather long)
    Feb 2006
    Poland
    5
    Re: Daikin Euwa
    I get the documentation somehow. Your codes are different than in mentioned chiller ( probably units are provided with different controllers depending on the country) I found the problem - discharge temperature sensor faulty. Any way Thanks for codes.
    Best regards from Poland.
    DarkRain's Avatar
    DarkRain Guest
    Re: Daikin Euwa
    Hello..
    I have this error
    how can i repair this ? please help me.
    Aug 2008
    London
    42
    55
    Re: Daikin Euwa
    Fault Codes
    Hi Frank - Do you have any wiring diagrams or know about the controller functionality?
    many thanks for your input
    Oct 2001
    Nottingham UK
    5,668
    Re: Daikin Euwa
    Same question asked via PM - answer given via PM
  1. Daikin VRV Checker
    By bobjob in forum Air Conditioning
    Last Post: 04-01-2009, 08:10 PM
  2. Daikin Analyzer
    By marc5180 in forum Fundamentals
    Last Post: 02-08-2008, 07:15 PM
  3. Daikin Controllers
    By airefresco in forum Air Conditioning
    Last Post: 15-05-2008, 08:08 AM
  4. !!big Daikin Problem!! Codes,u4,pj, And E0
    By airconengineer in forum Air Conditioning
    Last Post: 31-05-2007, 09:04 PM
  5. Daikin Model
    By Geofridgee in forum Air Conditioning
    Last Post: 12-07-2006, 09:23 AM
