Results 1 to 2 of 2
Thread: Air to air heat exchanger
10-02-2006, 03:53 PM #1
Hello All,
Does anybody have ideas about high efficiency low pressure drop small air to air heat exchangers?
Thanks in advance
VincentLast edited by Vincent Yu; 10-02-2006 at 05:31 PM.
11-02-2006, 01:43 AM #2
Re: Air to air heat exchanger
For air to air heat exchanger ,now there are usually enthalpy wheel and plate heat exchanger widely used.For small volume air flow,it 's better to use plate heat exchanger(aluminium plate for sensible heat recovery,paper plate for enthalpy recovery). the pressure loss is 100~200pa.
http://www.fantech.ca/en/index.htm for your ref
regards
LCI hear...I forget;I see...I remember;I do...I understand
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
Liquid reciever w/spiral heat exchanger
By Carlo Hansen in forum FundamentalsReplies: 10Last Post: 16-06-2006, 01:18 PM -
heat exchanger design
By Lc_shi in forum FundamentalsReplies: 33Last Post: 13-03-2006, 09:57 AM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM -
Restricted Heat Exchanger
By Abe in forum Trouble ShootingReplies: 1Last Post: 28-10-2001, 10:18 PM
