Results 1 to 9 of 9
    Sean LaDart's Avatar
    Sean LaDart Guest
    Scotsman Dc33pa Ice Maker Troubleshooting
    I am in need of assistance in figuring out what the problem is that I am having. Please bear with me as I am not an AC repairman - trying to fix on my own...
    The Ice Maker stoped making ice. What is happening is the pump is not draining the storage bin AND the water that supplies the ice maker with fresh water is not supplying the ice maker with fresh water. The jets that spray the water into the ice molds works - as a matter of fact, there is a huge chunk of ice in the area where the ice cubes are formed.
    Researching this on my own - I have concluded that either the WATER INLET VALVE or the PRESSURE SWITCH to the drain pump has gone bad. I am asking for another opinion on what the problem may be and some ways to narrow down to the component that may be at fault. Please ask questions as needed.
    Thanks!
    Sean A. LaDart
    Oct 2004
    Scotland
    1,454
    21
    Re: Scotsman Dc33pa Ice Maker Troubleshooting
    Drains are not usually pumped, they just fall in the mains drianage.
    Eh!
    I there is no water supply how can you get ice inside?
    I would guess otherwise.
    Make sure the drain at the back does not go upwards to the main drain and there is no blockage.
    Secondly, open the top of the ice machine and you will find the ice size thermostat. Make sure it is fastened to the evaporator properly.
    Chillin
    and go get a cuppa
    Sean LaDart Guest
    Quote Originally Posted by chillin out
    This ice maker has a pump built in that takes water (from melted ice) from the ICE BIN drain to a main house drain.
    Water fills the ice maker compartment and is recirculated with fresh water being introduced each cycle - mixed with the chilled water. Since no water is being introduced to the ice maker, the recirculated water continues to recirculate until it is frozen - no fresh water comes in to loosen the ice cubes. Hopefully, this makes sense.
    There is nothing to open on the top of the ice machine... This is a home unit - not a commercial unit... All of the equipment is located at the bottom part of the ice machine (underneath the ICE BIN).
    Sean LaDart
    Oct 2004
    Scotland
    1,454
    21
    Can you get a picture and the model number?
    Chillin
    and go get a cuppa
    Nov 2005
    Southampton
    45
    54
    although there is water coming from jets they may be partially blocked, most common prob with ice macines.
    get some food safe cleaner preferrably proper ice machine cleaner (it is a kind of strong vinegar)
    circulate for 30 mins then flush.
    if there is water in the circulation system and machine gets cold then this is probable cause.
    Also check bin level indicator as this smoetimes requires a clean (if light beam sensor)
    Oct 2003
    5,630
    34
    Sean LaDart Guest
    The model number is in the subject line (Scotsman DC33PA). No further posts are needed on this topic as I have decided to acquire a new ice maker - this one has had a long and good life (12 or more years...) It has earned it's retirement! Thanks for your input...
    Oct 2001
    Nottingham UK
    5,668
    Geesshh!!
    He gives up easily
    Oct 2003
    5,630
    34
    No thanks, Sean La Dart, you're always welcome.
  1. Amana refrigerator/ice maker problem
    By SCStewart in forum Trouble Shooting
    Last Post: 08-08-2010, 10:50 PM
