    Jun 2013
    3
    Coolant Substances
    Hi all, I'm curious about liquid coolant choices for an application I'm working on. I'm looking at something similar to a computer water cooling system, for which it seems propylene glycol is a popular additive. I'm wondering, for a similar system (pump, hose, coolant, etc.) Is there any material that can retain it's cool temperature for any extended period of time, a few hours maybe? Or is there a coolant that's more effecient that water + additive to maintain a cool temperature in this type of pump system? The other thing I haven't been able to find, is whether a solid could be used in that type of system (filled in the hose) and simply kept cold from the radiator or pump, rather than continuously having to pump a liquid through to keep it cold? Please let me know if you have any answers, I can't find them anywhere else! Thanks
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    Re: Coolant Substances
    Hi it sounds like you need a (PCM) phase change material, a bit more information on the application would be useful though?
    Jun 2013
    3
    I've got a ton equipment at home that I use for my projects. The cooling system never has to get that cold, say 55-65 farenheit, as my garage never gets too hot. But I guess if you think of the typical length of hose for a computer cooling system, I'd like enough to cover or wrap around 40 sq feet tops. I'm curious as to what my options are for this type of application. Thanks man!
Tags for this Thread
