Thread: hoshizaki im-240ame-21
25-06-2013, 04:53 AM #1
hi i was hoping someone could help me i am working on a hoshizaki ice machine and when i turn it on it starts filling with water and everything else starts up then the unit cuts out. there are no error leds showing. thanks
25-06-2013, 06:23 PM #2
Re: hoshizaki im-240ame-21
When you say everything cuts out do you mean as in tripping the fuse or just everything off ?
25-06-2013, 08:31 PM #3
bin stat , or optic ice bin sensor will cut machine dead without fault- hold the thermistor- if it got magic eye on it-clean the lenses
26-06-2013, 06:48 AM #4
Hey not not the fuse just the water supply and refrig side cut out as if cutting out on something i bypassed the bin sensor and the unit still cuts out also tried the hp switch. Im thinking its possibly the controller board
26-06-2013, 06:32 PM #5
Have you put gauges on it yet? It may have a lp switch on it as well that may be holding it off. Does sound odd that the water pump is staying off as well as the comp. Pcbs can be a pain when diagnosing.
