Results 1 to 2 of 2
    Jun 2013
    72
    1
    Angry Compressor unloaders
    need to find out how much of a problem by not using the unloaders . waiting for the software but need to run.
    Sep 2011
    45
    84
    14
    Re: Compressor unloaders
    The compressor is designed to run loaded or unloaded so should be fine to run either way. The compressor should run fully loaded if unloaders are not energized.
