23-06-2013, 06:28 PM #1
Residential Condenser to Chiller Conversion
Hi All,
New member... I'm a hydronic designer in the residential market. Very, very new to refrigeration.
I have become interested in figuring out how to convert traditional condenser units into chillers without a prepackaged "chiller barrel". I have seen techniques with a buffer tank and plate HX, flow switch, pump, etc... however I am curious about getting into an alternate idea to reduce points of failure.
specifically I am wondering if it would be possible to use a top-mounted steel or copper coil in a water tank as the heat rejection coil, with refrigerant in the coil. theoretically it should be similar in function as a very large "shell and tube" heat exchanger... there are even some such tanks with really large HX coils if necessary. One difference with shell and tube though is that fluid flow over the HX would be natural convective movement not forced... though on the heating side, we can usually transfer fairly large amounts of heat this way, I see no reason to expect it to be different in cooling modes.
I do not as of yet understand refrigeration nearly well enough to evaluate this from the refrigerant cycle/compressor control side. This could be a great way to get chilled water hydronics to a more viable level for clients who are not doing geothermal or air to water heat pumps/reverse cycle chillers. Condensers are, after all, much cheaper due to economies of scale in the residential market. if I can just add a coiled tank to a condensor and make chilled water reliably, I'd be a very, very happy guy.
anyone interested in batting this around a bit? Thanks in advance for even reading!
23-06-2013, 06:39 PM #2
Re: Residential Condenser to Chiller Conversion
some things never change
designers still think this is a one stop shop to do their job for him
if your not already in a position to know if you can/cant use a remote condenser to reject heat for a water chiller
you really dont have any of the basic knowledge required to carry out design do you
but I'm in a sarcastic but forgiving mood so here goes
start with the heat you wish to remove - match to a evaporator
match that to a compressor and tev for your calculated mass flow rate
then match that to a condenser
jobbakiss donnakissIf the World did not Suck, We would all fall off !
23-06-2013, 06:51 PM #3
using an alternative idea to reduce points of failure-your method of producing cooling/heating by relying on natural convection without flow switches,frost protection,circulated water will not work.
after all the messing about, its easier to buy a dedicated chiller with all the controls in place
23-06-2013, 07:09 PM #4
hey I would give you REP Points for that Install
but gotta find a few newbies to give some to; to share the love firstIf the World did not Suck, We would all fall off !
23-06-2013, 07:15 PM #5
now i given too much in 24 hours ... ruddy system huh
best take this public rep point then Install ( 10/10 )If the World did not Suck, We would all fall off !
23-06-2013, 07:20 PM #6
give us 1 of your rep points or a green square
23-06-2013, 07:23 PM #7
haha ya flash phurker
now you pm'ed me that me ole buddy Frank has been asking for me & missing me so
I will have to make more of an effort to make an appearanceIf the World did not Suck, We would all fall off !
