Thread: R401A table
    Dec 2008
    Brazil
    106
    R401A table
    I have doubts about R401A table below:
    http://mrmech.com/technical-referenc...4a-r401a-r401b
    For example: For R12 at -15 degrees celsius I have 11.8PSI in sucction line.
    I confuse because the table has 2 columns for the same refrigerant.
    So what what be the correct equivalent for R401A, 16 ir 10 PSI ?
    Moises
    Feb 2007
    2,473
    Re: R401A table
    Moises,
    R401a is a Zeotropic blend, the components in it boils off at different temperatures/pressures.
    Therefore the pressure will depend on if the refrigerant is in it's liquid phase or in it's gas phase. In your example above where you are looking at a suction line you therefore need to read the vapor pressure.
    Dec 2008
    Brazil
    106
    Re: R401A table
    Thank you. So, is it correct to calculate the subcooling by the liquid column of the table and superheat by the gas column ?
    Feb 2007
    2,473
    Re: R401A table
    Yes.
    4567890
