    Nov 2008
    nepal
    125
    Exhaust system On STP Plant Room
    Hi Friends...
    would some body help me to design the exhaust system on STP plant room...? or we can design the exhaust as we design for the toilets.or we have to follow the different norms and designing procedures, if so then please help me on this matter..
    11,025
    Re: Exhaust system On STP Plant Room
    Please explain - what does STP stand for?
    Nov 2008
    nepal
    125
    @Brian.it stands for " Sewage treatment plant "
    hookster's Avatar
    hookster is offline Veteran Poster I am starting to push the Mods: of RE
    Apr 2007
    Hampshire
    438
    32
    Hi Anil you will need to consider that all equipment should be Ex rated for extraction equipment due to the possibility of flammable gases being present. Notably methane will be present and you will require maintaining concentration below 5% (lower flammability range). This can be done with constant ventilation or sample monitoring (most cost effective considerations do apply). 4 - 6 air changes / hour is normal for ventilation capacity but could be as high as 10 - 12 air changes I would recommend you check your local building regulations.
    Nov 2008
    nepal
    125
    Quote Originally Posted by hookster View Post
    hi Hookster..many thanks for the information.according to you i have to buy the special ventilation fan for exhaust.do you have any booklet for designing the exhaust on this plant room..?
    Oct 2008
    newbury
    1,444
    37
