Thread: CPC Ultrasite help
12-06-2013, 01:01 PM #1
CPC Ultrasite help
Hi everyone, Im trying to use some cpc boards and an ultrasite program to monitor and control a simple test lab.
Got the monitoring somewhat figuered out. Now theres the room conditioning to control. Heat, A/C and Humidity.
I cant seem to locate the information in the software to get there.. Any ideas?
Thanks, Kengineering
12-06-2013, 07:00 PM #2
Re: CPC Ultrasite help
@kengineering
Can you confirm if you are using an RTU board to control Heat, A/C and Humidity? or just the AHU application mapped with the I/O board and points?
*Or you can call CPC techsupport (24x5) @ 770 4252724
14-06-2013, 02:16 PM #3
using an 8RO board , Im getting closer thanks.. Not understanding the settings controling the output n the software.. Ill try tech support
14-06-2013, 05:49 PM #4
Are you using an E2 BX for a controller?
15-06-2013, 11:41 AM #5
no, its a Refects box.
