Results 1 to 2 of 2
    Mar 2009
    9
    Chilled Water Buffer Vessel Sizing
    Apologies if this has been covered before but I couldn't find the answer I was looking for on the forums:
    I have a supermarket application using direct secondary cabinets and water chillers. The total chiller capacity is 380kW. There wil be two chillers (190kW each), each with 4 compressors. The fluid is 30% prop glycol with flow and return temps of -6°/0°C.
    The shop floor cabinets (around 60 in number) will each have a bypass valve arrangment when cooling is not required.
    My first question is do I need a buffer vessel and secondly how do I size it if I do?
    Any help would be very much appreciated.
    Jun 2011
    Australia
    44
    336
    21
    Re: Chilled Water Buffer Vessel Sizing
    Rule of thumb.
    Capacity of refrigeration, 380kw, multiply by magic number 6 equals 2280 litres of storage.
Tags for this Thread
