Thread: Cryogenics -80
    Apr 2005
    dorset uk (Brisbane) now
    22
    Cryogenics -80
    Hi can anyone help i need to find out the refrigerant charge as the unit that a compressor change,the refrigerant says mixture and amount of 0.260 Grams.I have spoken the the uk importer and he has no info on.
    Its a single stage unit that only needs one compressor with two circuits (like a cascade system)
    Unit detail
    Make-zhongke meiling cryogenics
    Model-DW-HW50
    Ps i have removed the refrigerant which has a smell of propane
    Could i use R508b ?
    Oct 2007
    manchester
    5,639
    45
    Re: Cryogenics -80
    r290,r600 mix or 5o8b usually -80 kit is 2 stage cascade- 404a for high stage
    no nameplate on the cabinet?
    last resort check with manufacturers as if it doesnt work its gonna take ages to get to temp
    ireland
    1,450
    41
    Re: Cryogenics -80
    Propane keeps the oil flowing, it'll need a small amount from vacuum, maybe only a gauge line full. Recommended charge and type of refrigerant is vital, don't guess at -80. Sounds chinese so god only knows what was in it originally.
    alec
