    jackal's Avatar
    jackal Guest
    thermo acoustic refrigerator: problem with stack heating
    Hello I'm a BSc physics student at exeter university (UK), and I'm working on a thermo acoustic refrigerator.
    I don't know how much you know about thermo acoustic refrigeration but I'm building what is called a TADTAR (Thermo Acoustically Driven Thermo Acoustic Refrigerator).
    Basically the device is a pressure vessel with two (Reticulated Vitreous Carbon) inserts called stacks. One stack acts as a heat engine, in that you heat one end of it and it emmits sound. This sound wave oscillates across an identical stack at the other end and "pumps" small packets of heat across it to induct a temperature gradient and so a net cooling.
    My problem is heating the prime mover stack tothe required 400 C
    The pressure vessel has an inside diameter of 39mm so whatever is heating it has to be small. I'm considering using a nickel crome element but electrically insulating it from the RVC stack would be hard.
    Does anyone have any suggestion?
    Thanks for your help,
    Jack
    Aug 2001
    Gold Coast, Australia
    600
    28
    Re: thermo acoustic refrigerator: problem with stack heating
    Hi Jack, & welcome to the forum. How about a very powerful torch bulb?
    Could you post the fuller explanation of the system that you showed me here for the guys, or is it hush-hush?
    jackal's Avatar
    jackal Guest
    Hi Freezergeezer,
    Yes I was concidering a powerful torch bulb, as its electrically insulated, but it has to be quite small.
    I'll post some more info on this later on as ive got to be off in a mo.
    cheers!
    Feb 2006
    WA, USA
    Cartridge heater. You can get them in what ever wattage you want. Most are rated to 1500F
    Will melt ice for $101/hr
    Luke Z's Avatar
    Luke Z Guest
    Arrow Re: thermo acoustic refrigerator: problem with stack heating
    There is a forum specific to thermoacoustic refrigeration systems.
    w ww.mecheng. adelaide.edu.au/anvc/thermoacoustics/forum/
    We would be happy to address / respond to the question there.
    Dec 2004
    Weihai,China
    800
    It's very interesting topic. hope it going here
    regards
    LC
    Jan 2006
    Valrico, Florida
    509
    Quote Originally Posted by Luke Z View Post
    Why there? It could be benifical on this forum.
