Results 1 to 12 of 12
    Dec 2005
    222
    Is a Potetial relay position sensitive?
    I didn't see an arrow or the word TOP on it so I figure it doesn't mater. What say you?
    Ken
    Oct 2001
    Nottingham UK
    5,667
    Re: Is a Potetial relay position sensitive?
    Well, I did a quick search on Google and most of them said " multiple mounting positions" then I found this - so now I'm not sure http://relays.tycoelectronics.com/da.../38_Series.pdf
    Feb 2006
    Calgary, Alberta
    66
    13
    Yes, potential relays are position sensitive. Each must be calibrated for the position it's to be used in. By installing one in an incorrect position, you risk, altering the Pick up and Drop out voltages.
    Rick
    vEStMaN's Avatar
    vEStMaN Guest
    P.relays usually sit in the upright position they are gravity assisted to switch over from start to run,lying them down (connections at the top) inhibits the cross over, causes the relay to stay in start position thus burning out the start windings.
    Feb 2006
    ct
    11
    depends on make of relay
    for instance copeland oem relay is position sensitive but an aftermarket such as mars is multi positional
    Feb 2006
    ct
    11
    usually the cheaper relays are position sensetive which is the reason compressor manufactures love them
    Dec 2005
    222
    This partiular relay came with a Danfoss factional hp. ( no markings) with a start cap and run cap.
    Ken
    Jun 2005
    California
    394
    Quote Originally Posted by kengineering
    Ken
    IT's position sensitive and normally closed
    Feb 2001
    Tampa Florida
    1,076
    I didn't know potential relays sensitive to position. Dang, all these years. Seems most are mounted spade up, but I recall hundreds mounted on the back wall and at other tilts.
    Feb 2006
    ct
    11
    if it came with replacement comp than play it safe and mount it the way the old one is mounted
    Dec 2005
    222
    The old compressor only had a start cap w a cmr relay. The replacement has both a start and run cap with a potential all supplied by Danfoss. No mounting bracket or instructions will have to make something.
    Ken
    Feb 2006
    ct
    11
    give me some numbers Ill look it up if you havent already isntalled it or blew it up.
  1. voltage drop on relay
    By Temprite in forum Electrical
    Last Post: 30-01-2006, 07:55 PM
  2. Potential Relay not staying open
    By labrosse in forum Technical Speculations
    Last Post: 05-08-2005, 08:14 PM
  3. Freezer Potential Relay not staying open
    By labrosse in forum Trouble Shooting
    Last Post: 28-10-2003, 01:53 AM
  4. Alternating Relay Circuit
    By herefishy in forum Industrial
    Last Post: 09-07-2002, 06:03 PM
  5. Drier Position
    By subzero*psia in forum Commercial
    Last Post: 23-07-2001, 10:28 PM
