    TRASH101's Avatar
    TRASH101 is offline Veteran Poster I am starting to push the Mods: of RE
    Mar 2007
    394
    Equipment selection help
    Looking for a recommendation to cool a large UPS and battery string "room"
    Trying to get away from high sensible domestic wall mounts and go for high sensible "no frills" commercial applications.
    Ideally I'd want a high air volume fan coil(remote stat, under ceiling mount) hooked up to DOL compressor/s with good head pressure control, preferably without hot gas bypass and expansion via TEV or EEV
    capacity is around 30kw.
    I don't do much buying these days and stuck with the same old gear on one site for the past 7 years........ so my knowledge of the market place is not very good
    Any advice from you chaps in the front line will be greatly appreciated
    Quidvis Recte Factum Quamvis Humile Praeclarum.
    Latine dictum, sit altum videtur.
    Si hoc comprehendere potes, gratias age magistro Latinae.
    Oct 2001
    Nottingham UK
    5,668
    Re: Equipment selection help
    Airedale have come a long way in recent years. Have a look at their close control stuff.
    http://www.airedale.com/v2portal/pag...ontent_091.htm
    TRASH101's Avatar
    Mar 2007
    394
    LOL they really have come a long way since the old ventus.
    Really don't need close control as occupancy is 0 99% of time....... personally I'd have a fresh air system with a CWS HX and preheat but its always the same response ......
    It's not an IT environment, it shares the same space as a v16 generator lol
