    3,856
    Open drive Frigidaire unit video
    Found this on a fruit farm, was bought secondhand in the 70's! Don't know if it would still run but would be fun to find out
    Joint in the pipework!
    http://www.youtube.com/watch?v=A1sZV...endscreen&NR=1
    Unit,
    http://www.youtube.com/watch?v=kMlFmmId4uc
    Oct 2007
    manchester
    5,639
    45
    Re: Open drive Frigidaire unit video
    wrights air con (now atlas wrights )used to use heating solder on there joints, and run suction and liq together and side 3 inch armaflex over it all- ripped out kit that had been in for 30 yr, but never seen joints butted up and joined
    Mar 2008
    232
    Thats a 3HP unit the largest twin cylinder unit Frigidaire made.
    They also made a tandem with the motor in the middle and a compressor on each side.
    Later they made a four cylinder model (in Line)
    Installed and serviced loads they went on forever.
    Location, United Kingdom
    Mar 2008
    232
    If you have the serial number that will give you the age of the unit, the first 2 digits indicate the date they are in reverse order ie 56--------- for 1965
    3,856
    Quote Originally Posted by B G Scott View Post
    I'll have a look next time i go there! I remember seeing a two compressor model with the motor in the middle in a dairy in London somewhere, probably in the early 90's. Scared me just o look at it!
