Results 1 to 1 of 1
Thread: oil level,s[temprite]
06-02-2006, 07:48 PM #1
supermarket pack LT system with 4; 25.hp compressor,s controled by A j.t.L pack controler.The problem is the oil in the compessor oil sight glass,s is very frothy and is pushing the float up in the oil regulator,s stopping oil supply.Fitted is a temprite oil sep [HP]type.The oil leves sep and goes througth A , A7 valve dropping the pressure to 24p.s.i. above suction pressue then it passes throught the suction header then onto the oil reg,s on each compressor. Are the oil reg,s able to cope with the temprite system or will I need to fit trax oil ,oil reg,s
By scotty w in forum CommercialReplies: 6Last Post: 06-08-2006, 02:07 PM
