Results 1 to 12 of 12
    Dec 2011
    spain
    63
    42
    Fitting Split Outdoor units in UK/USA
    I'm just curious as to how outdoor units are fitted in the UK and US with regard to health and safety. In Spain, a lot of installers just put the unit on their shoulders and walk up the ladder. I personally have a table winch where you place the unit on a bench and then wind it up, but even that is heavy and cumbersome. I also use an electric winch/pulley/ladder combination, using an extra set of ladders to pull the unit up. Are there any other options?
    manchester
    5,639
    Re: Fitting Split Outdoor units in UK/USA
    in the uk it depends on the site where its going- if its a customers house, then 3.5kw its on the shoulders, if its a site thats keen on health and safety then its a powered winch, stopped doing 5kw units on shoulder as it gets a bit twitchy on ladders
    Aug 2005
    uk
    82
    Genie lifter
    manchester
    5,639
    manchester
    5,639
    ireland
    54
    275
    seen guys here years ago using some kind gas powered hydraulic lift,they just lifted unit onto small platform turned on small gas bottle(probably nitrogen ) and up they went ,never seen outdoors going up as quick and you could carry the platform with one hand.Remember an awful feeling of jealousy at time we were lucky to be given old scaffold and drag them up
    Jun 2009
    Lusk , Dublin
    1,115
    THE JOB.http://www.workingatheightltd.com/ma...per_hoists.php
    Had one until recently ,got a rush of blood to the head and sold it to a mate.
    Uses C02 ,paid for itself half way through first job I used it on.
    Stu
    Quote Originally Posted by joe-ice View Post
    manchester
    5,639
    hss do em- for lifting ducting and ideally cassettes, cant do condensers as the platform is 4 ft off the deck
    ireland
    54
    275
    Quote Originally Posted by stufus View Post
    Stu
    Ya an older version of that but it was only about 2ft off the ground,it was some machine, at the time everything we done was using the donkey style of hoisting
    Dec 2011
    spain
    63
    42
    I think thats the one I have now and it just seems daft to have to lift something 4ft when you may just want to get to 8ft. I keep coming up with heath robinson type ideas but have yet to get one to do everything I want. In Spain, some of the wall brackets come with pre-drilled holes in the side of the uprights. This must be designed for something in mind.
    manchester
    5,639
    the wind up winch is better suited for condenser mounting- as its more sturdy, best way is to wind it up then fit the horizontal leg of the bracket under the elevated condenser then lower- the gas fired lifter is ideal for cassette's /ducted units as you can centralise them whilst elevated- be carefull though as they can leak and before u know it ur cassette has dropped about a foot!!!
    Last edited by install monkey; 19-05-2013 at 04:30 PM. Reason: are the pre drilled holes for mounting a drip tray?
    Sep 2008
    427
    I`ve used a Genie hoist before now, they`re a samll folding wind up fork lift that can fit in a Transit and go trough most doorways. The forks can be turned upside down to enable a cassette to be wound close to a ceiling.
    I was moving a small cold room condensing unit from 10 foot up a wall a few months back but as I only had a pair of steps I told the owner I`d need a tower to get it down. "No problem " he said and a couple of minutes he came back with an Indian guy who climbed the steps and, balancing the unit on his head, climbed back down. I didn`t ask for the method statement.
