Thread: Internal Pressure Relief
16-05-2013, 01:10 AM #1
What symptoms will occur if the (IPR) is parttially open? Would I have lower than other than normal suction and superheat at the evap .
16-05-2013, 01:12 AM #2
Re: Internal Pressure Relief
Would I have higher current draw as well
17-05-2013, 02:09 PM #3
HP and LP will be almost the same, compressor body will be extremely hot and AMPs will be lower.
20-05-2013, 12:26 PM #4
At the time of IPRV opening , you can hear the audible noise. The suction and discharge pressure equalizes rapidly
Regards,
Sendhil
