    Dec 2008
    chapeco
    Installation of compressor unit Sabroe 8180
    I am installing a compressor Sabroe 8180 how best vibration dampers or chubadores the base of the motor / compressor??
    Croatia
    68
    2,261
    Re: Installation of compressor unit Sabroe 8180
    Hi, diego palma
    Quote Originally Posted by diego palma View Post
    chubadores = ???
    My suggestion is to see recommendation within compressor manual for installation on vibration dampers.
    Best regards, Josip
    Dec 2008
    Portugal
    48
    1,020
    I think is mean foundation bolts ("chubadores").
    Diego, by the way I think the compressor you meant is an SMC 180 MK1 with 8 cylinders, right?
    Dec 2008
    chapeco
    So what better way to intalação foundation bolts ("chubadores") or vibration dampers, the manual says to use Sabroe bolts in the foundation.
    But I have a problem that the compressors are installed in a 2 floor slab which makes more vibration, so I would decrease it.
    Croatia
    68
    2,261
    Hello, diego palma
    My suggestion is to contact Sabroe .... then, maybe, to use type of vibration dampers for installation of compressors on ships!?!
    Best regards, Josip
    Dec 2008
    Portugal
    48
    1,020
    It makes more vibration because the foundation floor it is not properly designed (damping material » cork is missing)...you need to make civil work on the floor. So just use vibration dampers instead.
