Results 1 to 24 of 24
Threaded View
19-05-2013, 07:04 AM #16
Any ideas on my design for Flooded evaporator?
Im designing a evaporator for an appliance some freinds and i are going to build.
Its a -35c plate used for freezing deserts like cold rock sort of.
Anyway this is the design weve come up with, its a stainless steel folded and sealed to make a vessel with male flare connections attached to the bottom for liquid in and suction out.
Im thinking of running R404a at about 9psi which would meann the plate/vessel temp should be about -35c.
Does this make sense?
