Results 1 to 15 of 15
    Jan 2001
    Uddingston
    55
    Smile R600 Refrigerant.
    Iwas wondering if anybody has used this refrigerant as i am only using R404a these days and have no experience of this refrigerant. I belive this refrigerant is an iso-butane based refrigerant and i would like to find any practical information on this refrigerant, such as handling,charging and reclaiming if possible.
    Any information would be appreciated
    cheers Tony.
    Jun 2005
    S****horpe
    135
    Re: R600 Refrigerant.
    Hi Tony
    R600 is n-butane, R600a is isobutane, sold as Care 10. Boiling point is around -12C, most people use mineral oil. It's highly flammable so the usual precautions of earthing etc. for handling these kinds of materials. Recovery is still a bit of a grey area, but the latest seems to be that recovered refrigerant is to be treated as a controlled waste due to the oil which will be in it. On some sites where they have the facilities thye flare it off themselves, as unlike other refrigerants it doesn't need specialist incineration.
    For lower temp use there is Care 30 (R12 pressures but has a glide) which is a blend, or Care 40 (propane, R290), higher pressure again.
    It's a lovely day to pump some gas
    Jan 2001
    Uddingston
    55
    Hi johnny and des,
    Thanks for the information you have given me. The reason that i was asking was that a friend of mine has a domestic refrigerator that was manufactured in germany that runs on this particular refrigerant and we were wondering if it was paractical to carry out a repair on the fridge or bin it .
    cheers for your help,
    Tony.
    Jun 2005
    S****horpe
    135
    It's used in domestic fridges quite a bit, perhaps this is better asked in the domestic forum but I don't see why you couldn't do a repair the same way. Don't just get a can of butane from Camping Gaz Emporium, the refrigerant grade is a lot higher purity.
    Feb 2001
    Doncaster, England
    199
    I don't agree completely with the last post. Hydrocarbons have been used commercially in recent years in much larger systems than domestics. For example the Sainsbury store on the millenium dome site runs entirely on hydrocarbon refrigerants.
    I also know of several others.
    Tony
    Aug 2005
    5,326
    Quote Originally Posted by Peterson
    R606a is natural refrigerant. It's a very good refrigerant compared to R12, R22, R134A, R404a and Ammonia
    I take issue with the comparison of ammonia to the refrigerants listed. Ammonia is organic and bio-degradable, and has very high heat transfer properties.
    I also disagree with the comment about hydrocarbon refrigerants being only for small systems. I have worked on very large propane, propylene, and ethylene projects so I believe the comments are out of context.
    Croatia
    68
    2,299
    Are you speaking about R600 -butane
    or R600a -isobutane
    Anyhow "parfume" is much better. I'm with you US Iceman
    Croatia
    68
    2,299
    Dear Mr. Peterson
    are you this person: http://www.geocities.com/krasaein/
    Graywolf's Avatar
    Graywolf Guest
    Does anyone have experience reclaiming R-600? What reclaim machine do you use?
    Mar 2011
    Singapore
    212
    Graywolf,
    Most refrigerators used R600a isobutane now a day. Flamable gas and have many risks to repair.
    ignitation point are too low and in case of gas leak in confined/non ventilated places like kitchen or dining area then fire risk is there and dangeous because R600a is heavier than air. that's why most manufacturers used in small size refrigerators and non-servicible (one to one exchage) for refrigeration circuit. GWP very low, ODP is 0.
    Don't reclaim or service. No point to take risk.
    Mar 2011
    Singapore
    212
    sedsed's Avatar
    sedsed Guest
    Hello,
    I have a question. I heard that this refrigerant is not applicable with Aluminium tubes due to some kind of unwanted reaction. Is this claim true? Can someone help me about this problem.
    thanks
    sedat
    Mar 2011
    Singapore
    212
    Galvanic effect caused by Aluminium reacting with Copper and impact to the system is uncertain.
    The strength of Aluminium pipes are uncertain compare to Copper pipes that had been in use for decades.
    Nothing to do with R410A or R404 or R600a. Just under study stage, no one dare to take the risks.
    Of course R600a is more worse because flamable gas and many risks involved.
    Jun 2001
    N.Ireland
    1,632
    R606a is natural refrigerant. It's a very good refrigerant compared to R12, R22, R134A, R404a and Ammonia. Thermophysical properties are excellent. Of course in the future all small household refrigerator must be replaced with this refrigerant. But due to its flamability, the limitation can be only among small refrigeration system.
    Wrong R717 has way more uses and thermophysically is much more suitable that R600.
    BP in Grangemouth has a 800kw chiller on polypropylene, a bit bigger than a domestic
    Me thinks we have student who has been blinkered by his university training
    Pen and paper refuses nothing, learn to think outside the box or stay boxed in
    Kind Regards. Andy
    andrewkdx's Avatar
    andrewkdx Guest
    Cool Re: R600 Refrigerant.
    Quote Originally Posted by Andy View Post
    Can you take out the compressor from the r600 fridge and put in a r134 compressor or do you need major modifications to the system other than flushing and changing the drier?I dont like stuff that can catch fire...
    Kind Regards. Andy
    Can you change over to 134 compressor and what modifications should you make?
  1. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 01:39 PM
  2. Replies: 2
    Last Post: 16-11-2005, 06:34 PM
  3. Liquid refrigerant and bubles in sightglass
    By aygul in forum Trouble Shooting
    Last Post: 30-08-2003, 09:07 PM
  4. Refrigerant Reclamation
    By herefishy in forum Commercial
    Last Post: 23-07-2003, 08:19 AM
