    Jan 2006
    Croatia
    68
    2,261
    31
    DC vs AC inverters
    Hello guys,
    Who can tell why all inverters (Daikin, Toshiba, Hitachi) intended to work at very low outside temperature (down to -15'C) have DC motors?
    Oct 2001
    Nottingham UK
    5,668
    Re: DC vs AC inverters
    What makes you say DC - are there any AC inverters doing the same?
    As far as I know, the DC driven compressor allows better control at low loads = maybe this allows operation at -15C
    Jan 2006
    Croatia
    68
    2,261
    31
    Quote Originally Posted by frank
    Sorry Frank, I do not know and for that reason I am asking that question. Hope to find out
    Dec 2005
    Spain
    61
    Shining do an AC Inverter.... Does anybody know the pros and cons of each type!!
    :cool: Calvo :cool:
    Oct 2003
    5,630
    34
    I heard once from someone experienced in VFD's that an DC motor is much easier and cheaper to control then an AC motor.
    It's easier to hold a high torque an a DC motor because you can play with the field in stator and rotor.
    Seen on the mass production this could hold sense.
    You don't need all the electronics to generate a sine wave which gives serious noise on the net.
    Rest of the post moved to the electrical section.
  1. Heat Reclaim
    By chilled2005 in forum Supermarket Refrigeration
    Last Post: 05-05-2008, 05:32 PM
  2. Pacific Inverters?
    By mick2me in forum Air Conditioning
    Last Post: 30-07-2006, 10:14 AM
  3. Inverters
    By Latte in forum Air Conditioning
    Last Post: 31-12-2005, 04:13 AM
  4. inverters and rcd's
    By rbartlett in forum Air Conditioning
    Last Post: 11-10-2005, 07:14 PM
  5. Frequency inverters
    By Peter_1 in forum Electrical
    Last Post: 15-07-2004, 07:46 PM
