    Somerset
    69
    4,698
    A Load of Balls! Where have the Ball Bearings Gone?
    Following on.
    Check out the attached Photos.
    Aug 2007
    Adelaide Australia
    70
    562
    Re: A Load of Balls! Where have the Ball Bearings Gone?
    Hi Grizzly
    Was that motor still running or had it seized?
    Can't say I have ever come across a bearing that bad in something that was operational.
    Paul
    Somerset
    69
    4,698
    Hi Paul.
    Honest answer, I cannot remember.
    It span OK, despite having no front bearing. The rear which is a different size, does not seem to bad.
    It was turned off when I came to change it.
    I have one at the moment where I changed the shaft seal about 6 weeks ago, which is leaking again.
    This was before I came to the conclusion it's the bearings.
    Had I realised that then, I would not of bothered just to change the shaft seal.
    The 2 locally rebuilt ones are still sound!
