Thread: Husky fridge door switch
02-05-2013, 04:12 PM #1
Hello, I have a Husky (Irn-Bru) single glass door upright fridge. The door switch has melted a bit inside. What does this switch control? It looks like it supplies a live to something in the fridge when the door is closed.
Thankyou
djrock
02-05-2013, 04:43 PM #2
Re: Husky fridge door switch
Being a glass door, it will not be a light that it is supplying
It will more than likely be to stop the evaporator fan from
running when the door is open. So it is important that it works.
Rob
02-05-2013, 07:01 PM #3
or link it out so the evap fan runs when the door is open and shut- cheapest option
02-05-2013, 09:14 PM #4
Has the door dropped on the hinges?
07-05-2013, 04:07 PM #5
Whats the reason to stop the evaporator fan from running when the door is open? Is it to stop it sucking in warm air?
The door might not be 100% level since the top hinge has been damaged and repaired at some time.
Thankyou
djrock
07-05-2013, 06:06 PM #6
Yes to stop warm air being pulled into the cabinet.
