Results 1 to 8 of 8
    Apr 2012
    Iraq
    29
    610
    10
    N2 as refrigerant
    hi
    why nitrogen is not use as refrigerant in air conditioning and refrigeration application
    what the advantage and disadvantage
    69
    10,484
    Re: N2 as refrigerant
    Because it doesn't work in the present equipment.
    As you need to cool N2 to -195C to become a liquid it seems a bit pointless to use it in AC or fridge.
    Apr 2012
    Iraq
    29
    610
    10
    thank u
    any more info
    Aug 2001
    Gold Coast, Australia
    601
    22
    I remember years ago being told of a total loss refrigerated truck using N2.
    Iirc, there was a vent valve that opened at a given temperature to vent the warm N2. This in turn caused an expansion device to open, spraying fresh (low temp due to the pressure drop) N2 into the compartment.
    May 2012
    AUSTRALIA
    28
    what is the difference between liquid and dry nitrogen , why liquid nitrogen does not disappear in atmosphere like other refrigerants liquid valve of bottle is open. i have seen liquid only on televsion but it stays like liquid even with the open lid .
    i guess my question is understood.
    thanks guys
    Aug 2001
    601
    22
    Temperature.
    Jun 2010
    Yorkshire
    52
    504
    12
    If you could evaporate it and condense it within a system, it could be cascaded until the final cascade stage is glycol, cooling water to 0 deg C. Similar to providing a chiller for liquid cooled condensors.
    The cost of such a system would not be economical, but one could be built as a training apparatus to offer a practical example and an explanation, why different types of refrigerants are used for different temperature applications. Along with the varying weights of refrigerant for the same amount of heat loads. And each stage of cascade could have an enthalpy chart to explain why its called entropy.
    Waffle waffle waffle.
    50 hertz but 100s worse
    Apr 2012
    Iraq
    29
    610
    10
    thank u all
