    Apr 2012
    Iraq
    35
    623
    installing reversing valve
    hi
    is there difference in installing reversing valve horizontally
    or vertically
    some split unit came with reversing valve mounted horizontally
    or vertically
    does that matter or not
    3,856
    Re: installing reversing valve
    I don't think it makes much difference, if replacing one then make sure its the same way as when the factory made the unit, then it should work as designed.
    Apr 2012
    Iraq
    35
    623
    no im will not make change
    but asking why some company install it horizontally or vertically
    is that matter
    Oct 2007
    manchester
    5,639
    45
    http://www.invensyscontrolseurope.co...t.aspx?id=3615
    mounting can be in any position, as its only a solonoid and a piston.
    Apr 2012
    Iraq
    35
    623
    Quote Originally Posted by install monkey View Post
    thank you very much
    Oct 2009
    Sydney
    38
    69
    15
    iv been told not to mount it horizontally with the small capillary lines underneath, as on occasion oil can sit in them and affect the function.
    if its horizontal with the capillary lines on top, thats fine.
    from someone i work with who used to work in manufacture.
    Apr 2012
    Iraq
    35
    623
    Quote Originally Posted by Mick13 View Post
    thank you that was very useful
