    Jun 2010
    Russian Federation
    47
    Using Mycom compound F2016 like as vacuum pump ??
    Hi !
    May be somebody advise me , because I can't find any information in manual . I need to provide vacuum test , but I havn't vacuum pump.
    Jan 2006
    Croatia
    68
    2,263
    31
    Re: Using Mycom compound F2016 like as vacuum pump ??
    Hi, frozenatsea
    Quote Originally Posted by frozenatsea View Post
    Hi !
    For vacuum test we normally use a vacuum pump .... your Mycom machine is refrigeration compound compressor .... we never use refrigeration compressors instead of vacuum pumps .... and most important low suction pressure achieved with refrigeration compressor is not close to vacuum pressure at all .... my warm advice - try to find one good vacuum pump and do the job properly ....
    Best regards, Josip
    Jan 2011
    India
    7
    It is better to use a Vacuum pump to Vacuum. Mycom refrigeration compressor is design to run only on specified refrigerant, using it for air vacuuming is not recommended because the discharge condition such as discharge temp and pressure of the air are not same as of refrigerant and may cause damage to compressor.
    Jun 2013
    Not to mention with the compressor design you'll never be able to pull even a half-ass'd vacuum. There is a lot of design differences in compression compared to pulling vacuum. From the actual mechanical design to the lubricants used in it.
