Results 1 to 2 of 2
26-04-2013, 03:13 AM #1
how to know the estimation of Electrical Power Consumption (kW)
Greetings and I am new here, previously I work as Industrial Automation and Electrical Engineer but now im moving into HVAC field. This is completely new for me.
I am now working in a project of HVAC, Here some of the calculation i've done ;
OAHU-1
154800 Kcal/H
10500 CMH
516 L/min
AHU-1
16340 Kcal/H
14500 CMH
54.5 L/min
AHU-2
26660 Kcal/H
13300 CMH
89 L/min
I have found the formula to convert Kcal/H to kW
for example AHU-1
16340 / 5 = 3668
then
3668 / 60 = 54.5 kW (but this is not Electrical Motor Power Consumption)
How to calculate the estimation of Electrical motor Power Consumption (kW) ?
Thank you
09-05-2013, 12:36 AM #2
Re: how to know the estimation of Electrical Power Consumption (kW)
16340 Kcal/H = 19Kw, not 54.5kW
http://www.convertworld.com/en/power/
The electrical motor power consumption will be 19Kw * 3.41214 / EER
For example, if the EER = 11 then the consumption in this example will be 5.9kW
http://en.wikipedia.org/wiki/Seasona...ficiency_Ratio
