Results 1 to 2 of 2
12-04-2013, 05:43 PM #1
Need shell side impingement plate?
Hello!
I design a dry evaporator.The fluid in the shell side is 30% calcium chloride aqueous solution .According TEMA standard .the non-abrasive,single-phase fluid,If the ρV2 not exceed 2232 kg/m.s2.needn't impingment plate on the shell side. Does the cacl2 belongs to the abrasive fluid,need I put the shell-side impingment?
13-04-2013, 01:32 AM #2
Re: Need shell side impingement plate?
apply a re-stackable plate heat exchanger, stainless steel. Alfa Laval or similar
