Thread: Citymulti
    May 2008
    dublin
    80
    Citymulti
    I have a city multi p125 and 2 indoors p63s with one par 31 remote .the remote cable was never looped in ,can I change settings with a par 27 remote to get both units to run and then take off par 27 back off system if so how or will I just need to run a new cable
    cheers
    Mar 2009
    Uk
    121
    Re: Citymulti
    You need to run a new cable if you want to use the PAR 30.
    Mar 2011
    Singapore
    212
    Re: Citymulti
    Unfortunately when there is no centralized controller or system controller, ME an MA remote controller can not be used together in a system. Bet is to use all either ME or MA. Of course you need to run a loop (TB15) cable for grouping with MA. ME plus point is that you need not to run extra cable for such situation.
    May 2008
    dublin
    80
    Re: Citymulti
    Cheers joe . Just going to run a loop in . Had just heard that if I hook a par 27 up to one of the indoors I could tell it it has the same remote address and take the par 27 back off so I wouldn't have to run the loop.
Tags for this Thread
