Results 1 to 8 of 8
Thread: help please
10-04-2013, 07:35 PM #1
help please
we have a split system samsung ac unit model sh24ta8x and every time the compressor tries to start it pops the breaker on the house board.it was running fine but all of a sudden this happened.
when i opened it up i found one of the ceramic pieces on the pcb was broken the top one in the pic.Image2.jpg
any ideas here ?????? if i just replace that board ?what would cause it??? and where would i be able to get a new board etc ??????? im not very tec savy but i install ac for a living mainly industrial .im not a electrician or fridgy.regards mike
10-04-2013, 08:30 PM #2
Re: help please
after you fix the damage on the pcb
you must check why that happened
check the electric connection if they are good and there is no loose
check the voltage of the supply wire
check the compressor capacitor
check if there is no humidity on the pcb
10-04-2013, 09:06 PM #3
Re: help please
OK,
I got a different view. Before you replace any parts try to find out why it happened.
A good starting point would be to get a professional in to have a look at your system, failing that and as a minimum, ask your local electrician to check that the compressor isn't down to earth or if he can find any other electrical faults.
11-04-2013, 10:07 AM #4
Re: help please
primarily you need to check insulation resistance of compressor.
11-04-2013, 05:56 PM #5
Re: help please
its owned by a single mum that is struggling to make ends meet.so im trying tofind out how to fix as cheap as i can for her.i will check the compressor to see if its down to earth.thanks for the replies guys.
14-04-2013, 06:17 PM #6
Re: help please
I don't have anything else to offer here, except that that looks like a ceramic resistor, and they can fail under severe overload conditions. So yeah, check your compressor and electrical connections and see if anything else is wrong.
16-04-2013, 12:24 PM #7
Re: help please
Does pcb still work? Other than that disconnect the comp reset breaker , turn on system , does breaker blow again ? If no then your comps the problem , most likely
16-04-2013, 12:27 PM #8
Re: help please
Be carful tho with the leads when u disconnect and turn back on , they will be live
