Results 1 to 2 of 2
    Apr 2013
    Malaysia
    14
    Humidity Controller
    Clean Room as Cosmetic Lab with Dimension as following:
    2470mmx4500mmx2438mm with temperature of 4'C looking for humidity controller which require to reduce / dehumidifier RH from 78% to 50%.
    Any Model of Humidity Controller recommend for ?
    Thanks...
    Jun 2012
    dubai
    54
    Re: Humidity Controller
    contact any of bryair engineers they will help you for the selection
    http://bryair.com/
Tags for this Thread
