05-02-2006, 10:13 PM #1
Gas powered vrv's versus absorbtion chillers
I will post this in the chit chat section because my knowledge on the subject amounts to just chit chat.
What i would like to know is this:
If a building does not have adequate power to run a std vrv or chiller system, is the gas driven vrv the only solution ? or can an a(d)bsorption chiller be employed? Is this ecconomical/possible.
Don't worry, i havn't stumbled upon a big job , i am just curious.
cheers
eggs
05-02-2006, 10:27 PM #2
Re: Gas powered vrv's versus absorbtion chillers
I've fitted gas fired absorption chillers where the power supply was deficient, no problems.
When you consider that the smaller ones run off a 13amp plug top they're quite good...Brian - Newton Abbot, Devon, UK
06-02-2006, 05:20 PM #3
You could always consider CHP.
This would solve both the lack of electrical energy, provide absorption cooling from the waste heat and you also get heating and hot water
06-02-2006, 06:16 PM #4
Who makes a gas driven VRV?
Is that the unit I saw recently from Sanyo and....forgot the other one (First symptoms of becoming old appears...I forget almost everything)It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
06-02-2006, 08:56 PM #5
ahemmmm?
sorry Frank, whats "CHP"
cheers
eggs
06-02-2006, 10:32 PM #6
Originally Posted by eggs
basically a gas, oil or deisel powered generator (for the electricity) and the waste heat is used to provide the rest
By all accounts they are now making them quite small to suit residential applications
07-02-2006, 06:55 PM #7
hi
Mitsi heavey industries also make one , their new version is supposed to be the dogs dangly bits. and due out soon
08-02-2006, 05:12 AM #8
Interesting idea: use a biodiesel generator to sell power to the utility and use the heat to run an absorption chiller to cool your house.
How's that: an A/C that *makes* money when it's used.
Chillers versus packs
By Peter_1 in forum Technical SpeculationsReplies: 15Last Post: 17-01-2004, 09:48 PM
