    Aug 2009
    Downunder
    56
    40
    Coke Vending Compressor replacement
    Done a reasonable search though few hits regarding a Coke vending machine that has a faulty compressor, basically the fan wiring connector arc through insulation & burnt a hole through the side of compressor adjacent klixon. Obviously lost it's charge & comp needs to be changed.
    Ok here in Syd Aust. told that Carrier have replacement comps for these 115Volt units though
    when I contacted them were puzzled!
    The comp is a Matsushita Elec. model No. QA125V29CAU6, 115V.
    Can anyone shed some light with a replacement? If not 115volt change to 240volt using a relay perhaps?
    Should I look at a reco?
    All advice appreciated.
    manchester
    5,639
    Re: Coke Vending Compressor replacement
    get the details of the matsu sh it a compressor - displacement, gas,high /med/low back pressures, capillary or exp valve, starting method, psc or csr- dimensions, pipe positions, then you can compare with others for a suitable alternative compressor- danfoss ,kirby/tecumseh are reliable
    Aug 2009
    Downunder
    56
    40
    That's good but having trouble getting any further info off the existing comp other than I posted above!
    ireland
    1,450
    Size a replacement off the cubic capacity of the fridge, maybe ask a wholesaler to do it, is there a transformer fitted? Is it a Unifrigor fridge?
    alec
    manchester
    5,639
    http://industrial.panasonic.com/www-...AAB2000CE1.pdf
    panasonic own mat su sh ita cannot find the exact info- contact them for a spec sheet or equivelent
    manchester
    5,639
    http://industrial.panasonic.com/www-...+AAB2001+4++WW
    v looks like its been replaced by k
    Aug 2009
    Downunder
    56
    40
    Thanks IM reckon that could be the original runs on R12 an oldie.
    Probably go with the slightly higher capacity one. The unit does have a step down tranny from 240v-115v
    so could easily install a relay & run the 240v model.
    Thanks again very helpfull
