29-03-2013, 08:54 PM #1
Coke Vending Compressor replacement
Done a reasonable search though few hits regarding a Coke vending machine that has a faulty compressor, basically the fan wiring connector arc through insulation & burnt a hole through the side of compressor adjacent klixon. Obviously lost it's charge & comp needs to be changed.
Ok here in Syd Aust. told that Carrier have replacement comps for these 115Volt units though
when I contacted them were puzzled!
The comp is a Matsushita Elec. model No. QA125V29CAU6, 115V.
Can anyone shed some light with a replacement? If not 115volt change to 240volt using a relay perhaps?
Should I look at a reco?
All advice appreciated.Last edited by Brian_UK; 30-03-2013 at 10:01 PM.
29-03-2013, 09:17 PM #2
Re: Coke Vending Compressor replacement
get the details of the matsu sh it a compressor - displacement, gas,high /med/low back pressures, capillary or exp valve, starting method, psc or csr- dimensions, pipe positions, then you can compare with others for a suitable alternative compressor- danfoss ,kirby/tecumseh are reliable
29-03-2013, 09:44 PM #3
That's good but having trouble getting any further info off the existing comp other than I posted above!
29-03-2013, 09:53 PM #4
Size a replacement off the cubic capacity of the fridge, maybe ask a wholesaler to do it, is there a transformer fitted? Is it a Unifrigor fridge?
alecMostly found in the southern part of this green and pleasant land.
29-03-2013, 10:19 PM #5
http://industrial.panasonic.com/www-...AAB2000CE1.pdf
panasonic own mat su sh ita cannot find the exact info- contact them for a spec sheet or equivelent
29-03-2013, 10:23 PM #6
http://industrial.panasonic.com/www-...+AAB2001+4++WW
v looks like its been replaced by k
30-03-2013, 02:25 AM #7
Thanks IM reckon that could be the original runs on R12 an oldie.
Probably go with the slightly higher capacity one. The unit does have a step down tranny from 240v-115v
so could easily install a relay & run the 240v model.
Thanks again very helpfull
