Results 1 to 11 of 11
    Apr 2012
    Iraq
    30
    614
    11
    installing elbows in split ac connecting pipes
    hi
    i saw split unit ac
    but the connecting pipes between indoor and outdoor unit are strange
    the technicians add elbows to the pipes to decorating the exterior of the building
    the image will explain more
    as i know the elbow will decrease the pressure of the refrigerant then increase load on the compressor
    then decrease the refrigeration effect
    im right or not ????????
    Apr 2007
    30
    372
    Re: installing elbows in split ac connecting pipes
    why is the pipework coiled up before the condenser...
    Jun 2009
    Lusk , Dublin
    1,120
    The pipe is most likly coiled up because it was pre flared coils
    As for the elbows they are more than likely formed bends purely for neatness.
    How would you propose to do it without bending the pipe??
    providing the bends are done right and the diameter of the pipe is not significantly reduced the restrictions are minimal and so is the effect it has on performance.
    Stu
    Tool's ? check ! Condom's ? check !
    Oct 2007
    manchester
    44
    5,707
    tube cutters left at home when i installed this!!
    Quote Originally Posted by jdunc2301 View Post
    Apr 2012
    Iraq
    30
    614
    11
    i dont know
    the unit was installed before i worked there
    Apr 2012
    Iraq
    30
    614
    11
    Quote Originally Posted by stufus View Post
    Stu
    u mean there is no effect
    Apr 2012
    Iraq
    30
    614
    11
    Quote Originally Posted by install monkey View Post
    hahahaha
    Aug 2001
    Gold Coast, Australia
    601
    22
    As long as the total equivalent pipe length is still within the manufacturer's design spec, it shouldn't affect the operation of the system.
    I can't tell for sure from the photos if the evap. is below the condenser. But if it is, perhaps the pig tail is there to act as an oil trap.
    44
    3,800
    38
    Won't make any noticable difference, just think how many u bends there are in the condenser and evaporator to get five elbows in the interconnection pipe work into perspective.
    Apr 2012
    Iraq
    30
    614
    11
    thank u man
    Apr 2012
    Iraq
    30
    614
    11
    please close thread
