Thread: Ethylene Glycol
    Feb 2013
    Rochester, NY
    37
    Question Ethylene Glycol
    I have a screw compressor that uses an ethylene glycol/water mixture to cool the oil via a shell & tube heat exchanger. It is then pumped to a closed-circuit cooler on the roof and back. It also supplies underfloor heat for one of the spiral freezers.
    The system level is low and what I need to know is will any old EG work or do I need something special? I know I need something with a rust inhibitor because of all of the black pipe in the system but I've heard that certain cheaper grades of glycol won't hold up to being constantly recirculated. Anyone know?
    Iceman717
    Compressors in the basement, condensers on the roof, evaporators everywhere else. :cool:
    Dec 2010
    Toronto, Canada
    1,454
    Re: Ethylene Glycol
    FWIK, the base glycol will be the same and the difference is in the inhibitors. My own preference would be to clean it out and switch to propylene glycol which is not toxic but you have slightly different pumping and heat transfer characteristics. It is often less reactive with some plastic piping types.
    Feb 2013
    Rochester, NY
    37
    Re: Ethylene Glycol
    Quote Originally Posted by MikeHolm View Post
    That would be my preference as well but the powers that be won't go for that. I doubt if there is even any inhibitor in the system now.
    Iceman717
    Dec 2010
    Toronto, Canada
    1,454
    Re: Ethylene Glycol
    Tell them their insurance rates for spills will go down big time, haha
