Results 1 to 1 of 1
10-03-2013, 09:25 PM #1
Daikin Ducted Split System A/C Stopped WORKING Completely
HELP needed as my Split system Daikin A/C has stopped working.
Details:
* Installed professionally Nov 1997.
* Indoor Unit: FDFY100FVA Voltage: 240V, Freq: 50Hz, Phases:1
* Outdoor Unit: RY100FY1
* No remote; Indoor Control: BRC1B52/62
* Three zones
Symptoms:
* When the Indoor control Unit is pressed the red ON light comes up.
* Irrespective of the Mode used (Heating, cooling, Fan etc) and Zone used, Nothing Happens ie.
No air blows in any of the rooms, no air flowing in the Return Air Grille, Outdoor Unit is quiet too.
Fix attempted:
* Switched Off the A/C Isolation Unit in the Main Switch Board, waited 30 seconds, Switched on again - No change
Other symptoms:
* When the indoor controller is switched on, there is a slight CLICKING sound on the INDOOR Unit in the roof - there is some other minimal continuous sound after that but no air flows through the Return.
As I am a Pensioner, I do not want to call the Professionals if I can do something by myself. I am NOT a technician or an Engineer.
I have already paid a few hundred dollars in the last six months to fix two zones - as per Technician (who also originally installed the system) it is called replacement of Belime Zone Motor - very expensive - around $350 each time.
