Results 1 to 16 of 16
Thread: ofn regulator
    Feb 2008
    504
    21
    ofn regulator
    left standing next to new ac units did not even secure the cylinder must of been a good pressure test
    Oct 2007
    manchester
    5,639
    45
    Re: ofn regulator
    you get to see allsorts in this trade- saves breakin the dials on a regulator when the bottle falls over
    3,856
    Re: ofn regulator
    Suicide fitting...
    Oct 2007
    manchester
    5,639
    45
    Re: ofn regulator
    3000 bar inlet pressure on a full bottle of nitro, copper pipe rated at 50-60 bar
    3,856
    Re: ofn regulator
    Looks like the copper has swelled out a bit...
    Feb 2009
    telford
    2,090
    33
    Re: ofn regulator
    quick question,why not lay a nitro bottle down saves breaking guages,on this fitting to the bottle insane!!!! whoever made that needs help/advice quick.
    Feb 2008
    504
    21
    Re: ofn regulator
    if your going to use a fitting like that then your not going to worry about laying the bottle down the person using it was not even on site
    Sep 2003
    ISRAEL
    72
    4,248
    Re: ofn regulator
    Quote Originally Posted by install monkey View Post
    These bottle will not have more then 200 bar and copper tubes up to 3/8 will not burst.
    There are special bottles with 400 bar, not in our field.
    Feb 2009
    telford
    2,090
    33
    Re: ofn regulator
    take it off and cut it up you may save someones life!
    Feb 2008
    504
    21
    Re: ofn regulator
    chemi-cool so what about the service manifold the cylinder was connected to or the ac system that was pressure tested or the people in the area of the test
    Oct 2007
    manchester
    5,639
    45
    Re: ofn regulator
    check with climate ctr which company bought the nitro bottle- if theyre really helpful they could dig out the chargenote to see which chimp bought the bottle!!!
    Quote Originally Posted by martinw58 View Post
    Feb 2008
    504
    21
    Re: ofn regulator
    Oct 2007
    manchester
    5,639
    45
    Re: ofn regulator
    gaugelines rated for 60 bar- manifolds- if used- weekest point would be the sight glass of the manifold .also the system is only designed for pressure test of around 40-42 bar- transducer/pressure switches would req testing to ensure still accurate!
    Sep 2003
    ISRAEL
    72
    4,248
    Re: ofn regulator
    I work a lot with high pressure gases up to 400Bar in 50 liters bottles, there are about 8m3 gas in such a bottle, the pressure + the high velocity can cut you in two instantly. Accidents have heppened.
    Who ever work like that should be jailed and loose his license for ever.
    Mar 2013
    Australia
    34
    1
    Re: ofn regulator
    The person who did this must of been desperate to pressure test but did not have a reg with them. i am sure a safer way to test the system if this is a install and not a gas leak. Would to vac out the system with a vaccy stat ( unsure of the real name but it measures the mircons within the pipes you are vaccing out) if the system does not hold under 500 microns you know your in trouble.
    love this quote
    "All things are possible until they are proved impossible - and even the
    impossible may only be so, as of now."
    3,856
    Re: ofn regulator
    I'd bet they have broken their regulator and rather then admit it to their manager they have brazed onto the bottle connector.
    Remeber talking to a guy in NRS few years back, he said out of his company they only had two vac pumps, the rest of the guys had eith broken theirs or sold them on ebay.... Shocking what goes on....
