    Mar 2013
    32
    2
    Exclamation R744(CO2) trans-critical system components
    we are urgently need the following components for a R744(CO2) transcritical refrigeration system
    pressure should be 120Bar
    1.evaporator (air cooler)12Kw
    2.condenser 22Kw
    3.liquid receiver(liquid tank)
    4.oil seperator
    5.solenoid valve
    6.electrical expansion valve
    7.check valve
    8.sight glass
    9.dryer filter
    10. pressure controller
    11, pressure hose
    12.check neddle valve
    13. high pressure control valve
    14. safety valve
    If you can supply the above components, please contact me ASAP.
    May 2012
    54
    1,330
    30
    Re: R744(CO2) trans-critical system components
    Most wholesalers in the UK will either stock that
    equipment or be able to source it, have you asked any
    of the large wholesalers?
    Rob
    Oct 2003
    56
    5,519
    28
    Rob, hard to find components for more than 60 bar. Where can you find a dryer, sightglass for these pressures?
    May 2012
    54
    1,330
    30
    It's quite common in the UK because the supermarkets are using C02.
    You will find that common fittings (sight glasses excluded) are rated well
    above what C02 runs at and all it takes is a re-issue of an insurance test
    certificate.
    It is surprising just how high fittings are tested to prove them safe,
    it is a lot higher than the X 1.43 that it states in the EN378 standards.
    Rob
    Oct 2012
    Russia
    37
    391
    12
    I think you tell us about 2 stage system *****\heat-transfer agent\Cooler CO2
