Thread: Used/new equipment for sale.
Hello everybody
here is a list of used and new equipment we have for sale.
I have asked and received the webmasters blessing before posting this
This is mostly equipment from ships that have converted from R-22 to NH3, and it has been in operation up until the day we took it out.
The equipment have been sealed and charged with OFN, all equipment is stored in a heated warehouse. (except the northstar ice generator, see details)
Contact me on PM with questions. pictures can be provided upon request.
LIST OF HORISONTAL PLATEFREEZERS:
4 pcs . Horisontal freezer. KVAERNER PFH-13-1750/1120-90-34,(second hand)
-13 stations.
-Net plate dimensions 1750 x 1120 mm
-Opening between plate 34 - 90 mm.
-Designed for Ammonia pump circulation, with hot gas defrosting.
(freezers are in very good condition)
1 pcs . Horisontal freezer. MMC. PFH. Stainless steel.1200/1120-110-50,
-2001 Model. With stainless steel frame, very little used !
-8 stations.
-Net plate dimensions 1200 x 1120 mm
-Opening between plate 50 - 110 mm.
-Designed for R22 pump circulation, with hot gas defrosting.
2 pcs. Horizontal freezer. KVAERNER KBH-10E-1550/1120. ( factory new)
Number of stations : 9
Net. Plate size :1550x1120mm.
Opening between plate : 45-90 mm
(one is ready, two is partly assembled)
LIST OF OTHER REFRIGERATION COMPONENTS.
1 pcs. Ice maker generator. Type North Star. M20.SS.RFS 01. ( second hand )
Stainless steel model, with separate surge drum.
Capacity 10 tons a day with ice.
Dimensions. 900+1500 x 1500 x 1800 ( L x W x H )
Year 2001
(Note this is only the ice maker evaporator, no compressor)
-it is sealed and charged with OFN, but has been stored outdoors, so the drive for the ice scraper is in unknown condition.
1 pcs. Sea water condenser Type Teknotherm SK Ø273 -2500. 2 Pass . ( second hand )
Capacity: approx 200 kW. R22.
1 pcs. Sea water condenser Type Helpman HBX 13-225. 4 AIP . ( second hand )
Capacity: 400 kW (dt 12K) . R22. Flow 60 m3/h
Dimensions. ( L x W x H ) Year 2002
1 pcs. Sea water condenser Type Helpman HBCF 14-260-2 AIP . ( second hand )
Capacity: 600 kW (dt 12C). R22. Flow 80 m3/h.
Year 2005
1 pcs. Sea water condenser Type Helpman HBX 13-300. 2 AIP . ( second hand )
Capacity: 498 kW (dt 12K) . R22. Flow 60 m3/h
1 pcs. Sea water condenser Type Kværner KRA 1-43B . ( second hand )
Capacity: 384 kW(dt 12K) . R22.Flow 60 m3/h
Dimensions. ( L x Dia x W )
Year .
1 pcs. Hermetic Liquid pumps for R22. Type Cam 2/2 . Power 440 / 60 Hz ( second hand )
1 pcs. Hermetic Liquid pumps for R22. Type Cam 2/4 . Power 440 / 60 Hz ( second hand )
1 pcs. RSW Cooler. MMC KVA 355-4-1. Capasity 285 kW (faxtory new)
Delivered with oilreturn system, sightglass, exp.valve& relief valve mounted on unit.
Product picture: MMC_KVA.jpg
Image is representative of the product
1 pcs. Bitzer Screw compressor unit. R22. ( second hand ) 48 kW capasity at –38/30C.
Bitzer OSN 7471K. with 2 capasity coils. Motor 55 kW 220/380V 50Hz.
Oilcooler sawater cooled.
Unit was taken out of factory trawler in july 2006. System was tested and ok before dismounting.
2 pcs. Howden Screw compressor unit. R22. ( second hand ) XRV 163 -193 . kW capacity at –38/30C.
Compressor capasity coils. Motor 86/101 kW 380/440V 50/60Hz.
DNV approved
1 pcs. Kværner APV Hall Screw compressor. R22. ( second hand ) ( Only compressor)
Type HS 18 – 3,5 (1998) 258 kW capasity at –5/25C. Motor 75 kW 220/380V 50Hz.
Unit was taken out of vessel in july 2008. System was tested and ok before dismounting.
1 pcs. Kværner APV Hall Screw compressor . R22. ( second hand ) ( Only compressor)
Type HS 2020 – 3,2 (1995) 292 kW capasity at –5/25C. Motor 86 kW 220/380V 50Hz.
------------------------------------------------------------Last edited by Tycho; 15-03-2013 at 07:34 PM.
-Cheers-
Tycho
04-03-2013, 05:27 PM #2
Re: Used/new equipment for sale.
Please try and add pictures, even ebay do.
pictures will be coming as I get the time for it... sorry, Would like to comply with Chemi-cool (who has the best user name on here hands down), but work keeps me busy, so I will be handing out bread crumbs.
If you want pictures of a specific product faster, post here, or PM me and I will prioritize it...
Again, sorry I didn't have the pictures ready when I posted this...
Next week I will be in Croatia and won't be able to post anything.-Cheers-
Tycho
