Results 1 to 10 of 10
    Apr 2001
    2,099
    27
    Small Searle Cooler
    A heater ( the middle one) failed on a small Searle 2 fan cooler the other day. ( Its in a freezer room)
    I disconnected it, increased the defrost period and the bottom heater is now responsible for defrosting the whole coil.
    The middle heater is positioned within a void with a steel plate above it.
    How do I remove it?? I tried tugging it , but it did not shift.
    Would welcome some help
    Abe
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Sep 2005
    uk
    499
    21
    Re: Small Searle Cooler
    have a look for any clips. if there are none then tug harder.
    Takes a licking, keeps on ticking.
    Dec 2005
    u.k.
    It could be that the heater rod has blown and split the casing so that it will not move past the surrounding fins, if this is the case then you are in the s**t a bit, are there any other drillings in the evap that will take the new heater? So that a new heater can be installed close to the old one?
    Apr 2001
    2,099
    27
    No Drill holes, The way this coil is designed , it it like split half way down the middle, so a new heater can easily be removed and a replacement slotted in.
    As Sling says.........Ill try Tugging it little Harder
    Thx
    11,024
    Quote Originally Posted by Aiyub
    ....... so a new heater can easily be removed and a replacement slotted in.
    Well, that didn't work then did it ?
    Oct 2004
    Scotland
    1,454
    21
    Hi Abe,
    Don`t pull at it ...
    The heater comes out with the metal plate. Bend the lugs at both ends on the plate, push it left then push the right side out the coil followed by the left side.
    You will now find the heater is clipped to the plate.
    Chillin
    and go get a cuppa
    Jan 2003
    East Anglia
    1,160
    Hi Aiyub,
    Why is always the middle one that goes. As Chillin cay's just bend the lugs at each end and it will slide out although the slightest bit of ice in the coil and you are wasting your'e time trying.
    I have lost count how many of these i have changed a little chef's around the country and each time i have had o get them to empty it overnight and switch it off to do it.
    Good news is NRS usually have the heaters on the shelf
    Fatboy
    Apr 2001
    2,099
    27
    Thx Chill..........Fatboy........
    Ill have another go 2 moro, although, that one solitary heater at the bottom is somehow keeping the ice off
    I do have the defrost on for a full 45 mins though, every 6 hours
    Oct 2003
    5,630
    34
    Aiyub,
    Look once here http://www.searle.co.uk/techdoc/Engl...%20KS%20KM.pdf
    I think it's a KS or KM you're talking about, that stylish one with the blue flat grilles on it.
    Aug 2005
    Australia
    42
    44
    Have had the same happen to me once before which made the old heater very hard to remove when it blew it split apart in the middle of the evap.. Got a steel rod that slid in the hole and knocked the old one out....
  1. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  2. Thermo-syphon Oil Cooler
    By B.B. in forum Industrial
    Last Post: 31-10-2005, 01:25 PM
  3. Searle Celler Cooler
    By donetello in forum Trouble Shooting
    Last Post: 21-07-2005, 08:09 PM
  4. Searle cellar cooler control problem
    By iceman007 in forum Electrical
    Last Post: 06-07-2004, 08:57 PM
  5. Searle Evaporator
    By Abe in forum Commercial
    Last Post: 07-12-2002, 11:59 AM
