    Mar 2013
    United Kingdom
    40
    1
    Question Carpigiani Pronto 4 Batch freezer motor is not working
    Hi everyone,
    I live in the UK (Watford) and last year bought a Pronto 4 batch freezer that is no longer being made. I left it on for over an hour tonight and the ice cream had frozen solid (rather than smooth). The motor is now longer working but the machine can still freeze liquid.
    Could anyone advise on what I can do?
    Thank you!!!
    Rowan
    Oct 2007
    manchester
    5,639
    45
    Re: Carpigiani Pronto 4 Batch freezer motor is not working
    CARPIGIANI UK
    Faculty House
    214 Holme Lacy Road
    HR2 6BQ Hereford
    Tel. +44 1432 346 018
    Fax +44 1432 346 019
    Email. info@carpigiani.co.uk
    may have a technical dept
    Feb 2007
    2,473
    45
    Call a professional?
    Failing that, if you by the motor mean an electrical motor for a stirer type of thing then there is 2 things that can be done. Remove the motor and either find a like for like replacement or have it repaired. (Try searching yell.com for "motor rewind" in your area.
    ireland
    1,450
    41
    Is it a belt drive motor? Could be belt has snapped or slipped, not familiar with the model.
    quickest answer is as above, call for service, if you have a few days, kill the power and pull the covers off the unit and take some pics?
    alec
    Auckland
    74
    3,357
    37
    Don't know the exact model but twin and single barrell churns are controlled by motor torque sensor, if barrells are frozen then sensor not setup correctly and drive motor has stalled, and most likely tripped on thermal overload manual reset required.
