Thread: Mr Slim
    Apr 2001
    2,099
    27
    Mr Slim
    An owner of a dress shop calls me, he says his AC , cassette , at certain times emits this foul smell from his ac
    ( in heating mode)
    The only thing I can think of is that it may have a fresh air duct fitted and this is picking up some smells from, an outside source
    He says next door is a fish and chip shop
    Any thoughts?
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Nov 2005
    wales
    52
    12
    Re: Mr Slim
    Sometimes this is caused by perfume !
    Chemicals condense on evaporator when run in cool mode and burn off when in heat mode - smells like cat pee
    Try washing evaporator - good luck
    Apr 2001
    2,099
    27
    Re: Mr Slim
    I never would have thought of that
    It figures all right, the women who frequent this shop are dressed to the nines and full of Oriental , Eastern perfume
    Maybe you may be right
    Re: Mr Slim
    Remember Abe when you are cleaning filters that we all change our skin once a month.
    Where do you think all those spare flakes of skin end up ?
    So the accumulation of general dust, shop cleaning materials, perfumes, deodorants and bits of skin add up to quite a c*cktail to settle on the fan and the coil.
    Don't forget your facemask when you're doing the coil clean.
    rbartlett's Avatar
    rbartlett Guest
    Re: Mr Slim
    Quote Originally Posted by milo
    We had this in a jewellers in bath. After about 2 months of running he phoned to say it stank.. We were completely baffled and repeated returns revealed nothing.
    The manufacturer (mitsi) even visited and couldn't see any reasons. then by sheer co-incidence the customer mentioned that years and years ago it was a perfumery. It turned out that the a/c was dragging 100 years of smells out of the very fabric of the building.
    The best we could do was stuff the intake grill with a activated charcoal filter...which we would change every other month.
    Richard
    Jul 2005
    Ireland
    164
    Re: Mr Slim
    Hi Abe,
    There is a bacteria that grows inside the Mitsu units it forms when the indoors are very dirty and when the Unit goes to heat the high temperatures cook the bacteria this usually smells like dirty cats. If this is the case strip and clean the drain pan there is also a strip of foam that is stuck to the bottom of the evaporator coil. its about 10mm square and runs around the bottom of the coil it stops the fins scratching the drain pan. Remove this as this is where the bacteria grows.This is a very common problem with the Mitsu's
    T
    ireland
    1,451
    Re: Mr Slim
    Abe
    Try using fairy anti bac mixed with water, works a treat!!
    Al
    5,667
    Re: Mr Slim
    Hi Abe
    Have a look at this site - good coil cleaners here.
    They are available at NRS (Climate Centre) among others.
    We find the Envirocoil to be good for this problem.
    http://www.advancedengineering.co.uk/
  1. mr slim p8 error code
    By Krups in forum Air Conditioning
    Last Post: 17-02-2011, 07:18 PM
  2. mitsubishi mr slim master and slave
    By r600a-bang in forum Air Conditioning
    Last Post: 24-07-2006, 10:24 AM
