Page 2 of 2 FirstFirst 12
Results 51 to 54 of 54
  1. #51
    2,577
    29
    Re: Sub cooled r22 still flashing?
    Attachment 10154Drew tis picture may satisfy you in regards to sub cooled liquid & liquid/vapour on P/E diagram
  2. #52
    Apr 2001
    73
    5,069
    29
    There is no concept in refrigeration that confuses more people than the static gas law which says you can't have superheat in the presence of liquid nor subcooling in the presence of vapor. The key word here is static, meaning non-energized. As soon as energy is applied, it all changes. It is only true when the system is off.
    In a functioning system, it is entirely possible to have superheated vapor bubbles surrounded by subcooled liquid and subcooled liquid droplets surrounded by superheated vapor... and this is in fact common in portions of the liquid and suction lines.
    Velocity carries the bubbles and droplets far past the points where you might expect them to disappear. That's why you need substantial amounts of subcooling to clear a sight glass and substantial amounts of superheat to avoid flooding the compressor. How much you need depends on the velocity.
    It varies, but essentially you need 10-15F SC (5.5-8.5K SC) to clear the sightglass... and sometimes a little more. If any of the TXV's are flooding the coil, it should be fixed before you try to clear the sight glass.
  3. #53
    Apr 2001
    73
    5,069
    29
    You might find this thread helpful:
    http://www.refrigeration-engineer.co...rigeration-101
  4. #54
    Apr 2008
    Tasmania
    214
    12
    Thanks Ranger1 and Gary. I like the sound of a static gas law as opposed to the other type.
    ill see further what the inter web has to say.
    The more I learn the less I know......
